Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 860 Parts Online
Re: Ford 860 PTO Problem
soundguy
05-29-2013 18:08:36
most likely what the others said about the clutch.. however.. i think i'd pull the shaft for a looksee.. even though it will drain the rear 2 sumps oils.
i've seen a shaft on a N shear past the pump and freewheel from contact betweent he halves.. but there was enough thrust bearing play that 'hand' pressure would stop it and make it gall and grind at the shaft break.
hyds worked.. :) since damage was post pump. :)
probably not it. worth looking if it beeds an oil change...
Jmitt
05-30-2013 07:33:20
 Re: Ford 860 PTO Problem in reply to soundguy, 05-29-2013 18:08:36
Thanks I have pulled the shaft checked it the shift lever and collar all seem good. So it looks like I am clutch bound. If I buy a new clutch do I still need a adjustment fixture for it or should it come in proper and just use a line up tool for the pilot bearing.
Thanks Jason
soundguy
05-30-2013 07:40:02
 Re: Ford 860 PTO Problem in reply to Jmitt, 05-30-2013 07:33:20
those 2 stage clutches should come pre-setup
Jmitt
05-30-2013 08:42:09
 Re: Ford 860 PTO Problem in reply to soundguy, 05-30-2013 07:40:02
Thanks for every ones input
Jason
