Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Ford 961 Diesel
Texas!
05-29-2013 13:43:11
The Ford diesels had 2 manifold heaters (they look like spark plugs from the outside) installed in the intake manifold to heat the air before attempting to start in cold weather. I know you're in MN or WI but I don't know the temperature there right now. Typically when a diesel gets hard to start the owner will start using ether as a starting assist and then the engine gets "addicted" to the ether. I have owned a 861D for over 10 years now. The manifold heaters are not functioning and in the winter I have to use ether to start it. It smokes all of the time it's running. But it has been serving me well for over 10 years now in that condition.
Does the double clutch work properly (PTO and Drive clutches)? A rebuilt clutch assembly for the X6X tractors costs around $400.
Colin King
05-29-2013 18:27:08
 Re: Ford 961 Diesel in reply to Texas!, 05-29-2013 13:43:11
Texas, Have you had any need for engine work? Any sense on parts availability?
This tractor would mainly see use in weather that was 50 degrees and higher. Occasional winter use if I were to find a snowblower.
Thanks for your help!
Colin
Texas!
05-29-2013 20:04:24
 Re: Ford 961 Diesel in reply to Colin King, 05-29-2013 18:27:08
Parts are no problem at all.
My 861D jumped out of 3rd gear going uphill, downhill, straight & level- it didn't matter. As soon as I let the clutch out in 3rd it would jump to Neutral. It required a complete trans disassembly to fix it. The worn out part cost me $50. I put in new bearings and seals while I was in it and total parts cost was about $500. So make sure the one you're looking at doesn't jump out of 3rd.
Colin King
05-30-2013 05:09:03
 Re: Ford 961 Diesel in reply to Texas!, 05-29-2013 20:04:24
Good to know! Thank you, sir!
Colin
