TractorLinks.com
Show Parts for Model:
Re: 7710/8210 style rear end transmission oil?
RodInNS
05-29-2013 05:21:51
77/8210's had common transmission and rear end hydraulic systems so it's one check point, one fill point for a common sump. Basically, Ford tractors work like this... if it's a 3 cylinder chassis tractor, the hydraulic and rear end/hydraulics are different sumps. If it's a 4 or 6 cylinder chassis tractor then they use a common sump. Again, I say CHASSIS. There are 4 cylinder tractors out there that are built on the 3 cylinder chassis such as the 4830 and 5030... and there are '4 cylinder chassis' tractors such as the 78/79/8210 that use the 6 cylinder engine.
Rod
soundguy
05-29-2013 06:12:12
 Re: 7710/8210 style rear end transmission oil? in reply to RodInNS, 05-29-2013 05:21:51
wouldn't hyds and rear be common on a 3 and trans seperate?
and on a machine like a 5000/4 cyl. you have the early seperate sumps.. but later or DP a common?
RodInNS
05-29-2013 06:40:07
 Re: 7710/8210 style rear end transmission oil? in reply to soundguy, 05-29-2013 06:12:12
Thought that's what I said... hyd/rear is common on a 3.
Yes, early 5000's were also separate boxes but given the question was in the context of 10 series... they are common sump at that point, DP or not.
Rod
soundguy
05-29-2013 06:49:07
 Re: 7710/8210 style rear end transmission oil? in reply to RodInNS, 05-29-2013 06:40:07
tis si what you said.. just sounded a lil confusing to me. figured if it confuses me.. it will confuse others:
" if it's a 3 cylinder chassis tractor, the hydraulic and rear end/hydraulics are different sumps"
RodInNS
05-29-2013 13:51:56
 Re: 7710/8210 style rear end transmission oil? in reply to soundguy, 05-29-2013 06:49:07
Oopsie... I think when I wrote that originally I had put transmission and rear end/hydraulics are different... wether I deleted that or what, I don't remember. That's what I had in my head anyway.
Tis corrected now.
Rod
soundguy
05-29-2013 17:54:25
 Re: 7710/8210 style rear end transmission oil? in reply to RodInNS, 05-29-2013 13:51:56
i was thinking one of those words might been transmission in disguise. :)
i type on a tablet and do that all the time.
so hard to correct and edit or even type on this tablet .. i can see how typos' happen all too easilly.
later bro!
cd1
05-29-2013 06:10:34
That's what I always thought but I read that post and started second guessing myself. I've had axles out to put brakes in and split for rear main seals but never much in between.
