TractorLinks.com
Order Ford 800 Parts Online
Re: 800 ford
Sean in PA
05-28-2013 19:45:43
It's not on the transmission, it's on the top cover of the rear axle center housing, just to the rear of the transmission. The easiest, in terms of finding something new to do the trick is to buy a hydraulic adapter plate that goes under the existing option plate and gives you a couple of extra ports that you can then plumb to any aftermarket control valve that you like. This site sells the adapter plate Here
J Bruns
05-28-2013 20:00:27
 Re: 800 ford in reply to Sean in PA, 05-28-2013 19:45:43
Ok that's what I meant is the rear end not the Trans sorry, that's what I was going to do anyway is just make a plate for a different valve but for $50 ill get that one and does this port have a relief valve or will the new valve need one and do these tractors have any type of filter on the hyd system. Thanks
