TractorLinks.com
Order Ford 4610 Parts Online
Re: Ford 4610, PTO stops when going up hill
RodInNS
05-28-2013 19:46:27
Could be a problem with the intake pickup. Add some oil and see if that helps...
A modest overfill is not going to hurt. It's actually recommended if you're working on steep grades.
Rod
david1
05-28-2013 19:51:37
 Re: Ford 4610, PTO stops when going up hill in reply to RodInNS, 05-28-2013 19:46:27
Does it matter whether you add it to the filler in the rear end or the one down by the gear shifts.
RodInNS
05-28-2013 20:08:41
 Re: Ford 4610, PTO stops when going up hill in reply to david1, 05-28-2013 19:51:37
In the rear... What dipstick are you checking? Most 10's I've seen have a level plug on the right side of the rear axle center housing. The transmission has a dipstick...
30 series tractors have sticks for both..
Rod
david1
05-28-2013 20:56:22
 Re: Ford 4610, PTO stops when going up hill in reply to RodInNS, 05-28-2013 20:08:41
I was told that it was not 2 separate areas, that the fluid would go to both no matter where you poured it in.
RickB
05-29-2013 02:36:30
 Re: Ford 4610, PTO stops when going up hill in reply to david1, 05-28-2013 20:56:22
You were told wrong.
