TractorLinks.com
Order Ford 800 Parts Online
Re: 800 ford
Royse
05-28-2013 19:06:14
I've heard of a couple different ways, but probably the easiest
if you can find the valve is to mount the original style spool valve
under the front of the seat.
Just remove the blank cover that should be there now and bolt it on.
This is a dual spool, there was also a single spool.
J Bruns
05-28-2013 19:31:44
 Re: 800 ford in reply to Royse, 05-28-2013 19:06:14
Ok thanks so it is that plug on the Trans there that tractor in the pic looks a little newer than what this is. It's painted red and has the shifter that goes up and down with a spring and the starter button is next to it will this plug be in the same spot I guess? Also is the relief for the pump in the Trans and do these have a filter anywhere? Thanks again
