Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Ford 530 Square Baler
fatbob50
05-28-2013 12:47:31
36 coupe, Thank you for taking the time to answer.
I am not concerned about the bill hook as it has nothing to do with getting that pin out. But it is the newer type with the bearing roller on it. It is not the old type with the bronze. You are right and I did put PB Blaster on it every day for a week. I pulled on it with very little pressure and the bolt twisted in two as you can see in the picture. You are right and I wish the bolt had not broken, it would have made my life so much easier. But the bolt did break.
My original question was and still is that I need to get that broken bolt out. I do appreciate your time in answering this question. Bob
RodInNS
05-28-2013 19:58:11
 Re: Ford 530 Square Baler in reply to fatbob50, 05-28-2013 12:47:31
If your main concern is getting the broken bolt out... most likely you will need to drill the bold and use an easy out unless there's enough above the surface to get a vice grip on it and apply some heat to the knotter frame. If you have to drill it... I'd probably remove the whole knotter stack from the baler taking VERY carefull note of where all those spacers go exactly. Then you can get clear access to the knotter frame to drill it. I would not disassemble anything beyond that unless it's absolutely necessary and that includes leaving the twine discs alone.
The sad part of this saga is that you probably didn't need to do any more than adjust the tension on the twine holder spring... and didn't need to touch that arm at all.
Rod
