TractorLinks.com
Show Parts for Model:
Re: Ford 530 Square Baler
RodInNS
05-27-2013 15:00:07
What part are you trying to change?
To get the twine holder out you will need to remove the twine discs first. To do that you need to drive the hidden roll pin from it's drive gear... Then remove the twine discs. Then the holder will probably come off. It looks like there is a shoulder on the pin that prevents it from falling out of the holder.... so if it's loose in the knotter frame it should just come out once the discs are gone.
Rod
fatbob50
05-28-2013 12:58:22
 Re: Ford 530 Square Baler in reply to RodInNS, 05-27-2013 15:00:07
Rod, I am trying to replace a broken bolt. It is the one in the picture (my pen is pointed at it). The broken bolt is a 5/16 bolt. It is the one that holds tension on the bill hook. It is the one in the picture with the spring in it and the arm (the roller pressure arm and is number 20 in diagram). I do appreciate your help and thanks for hanging there with me, Bob
