Anonymous-0
Having issues with all new wiring. My tractor burned (don't ask) so I
am rewiring it and converted to electronic ignition and 12 volt
system. The alternator is a single wire alt. Just as a test I was going
to see if I could get the engine to turn over but as soon as I hooked
up the battery it turned over- I did not push the start button and I
don't have a keyed switch yet (I was just going to touch two wires to
make the loop). I even disconnected the push button wire to the
solenoid, still turns over. What gives? Also do I still need the 6 volt
voltage regulator ?
voltage regulator ?
