Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford NAA Parts Online
Re: New wiring 12 volt Jubilee
Jason Kass
05-20-2013 15:21:57
I think it might be my relay. Anyway to test with ohm/multimeter?
TimPa
05-20-2013 16:09:19
 Re: New wiring 12 volt Jubilee in reply to Jason Kass, 05-20-2013 15:21:57
ohm test - 1. mark wires then remove them. cannot have anypower on terminals for ohm test. measure from one small post to the other small post (this is the coil). the ohmmeter should read some small ohms. maybe 2-30. then measure from one larege post to other large post (this is the contacts). should read infinity, or open. post back with any readings other than this.
Royse
05-20-2013 16:39:33
 Re: New wiring 12 volt Jubilee in reply to TimPa, 05-20-2013 16:09:19
Tim, his Jubilee should have a three wire solenoid with only one small post.
The coil hooks between the small post and the large post on the battery side.
The measurements are the same as you posted, just one less terminal. :)
