TractorLinks.com
Order Ford 5000 Parts Online
Re: Ford 5000 dash lights
Fordfarmer
05-20-2013 06:54:49
Oil light should have the shape of an oil can. Pretty sure it's on the right side. The 'arrow' you're seeing is the bottom part of a lightning bolt, for the electrical system.
sixbales
05-20-2013 07:29:59
 Re: Ford 5000 dash lights in reply to Fordfarmer, 05-20-2013 06:54:49
I have that light with the arrow pointing down on my 3600. It is supposed to be an air intake restriction warning light. If the filter gets plugged, or if the precleaner/screen on the air intake tube gets plugged, there is a restrictor switch that senses the additional suction pressure and triggers an alarm.
I"ve looked in the New Holland Online Parts Store, and I do not see a restrictor switch on a 5000. I don"t have the switch on my 3600 either. So my light only works I initially turn the key on and start the tractor.
If you have one, the restrictor switch is mounted on the air intake tube. That light gets its ground circuit through the restrictor switch.
Fordfarmer
05-20-2013 10:30:06
 Re: Ford 5000 dash lights in reply to sixbales, 05-20-2013 07:29:59
5000's only have two idiot lights... oil and charging.
