600 serieS ford tractor
Randy Greer
New User
I have a 600 that was running perfect and the next day I tried to use it and it started backfiring and blowing black smoke. I have checked valves, compression points, coil, plugs, gas,and nothing helps.it will crank and idle and when you throttle up it starts popping
Black smoke says it it running way to rich. Check the air cleaner and make sure it is good and not full of water and dirt. Also try pulling the carb drain and letting gas flow for a few minutes. Catch it to look for dirt etc in it. The float maybe sticking also
