Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 4000 Parts Online
Re: Fluids Ford 4000 Industrial
Jim.UT
05-18-2013 10:15:14
Sounder, Bink is my B-I-L and a first time tractor owner. I helped him find this unit. It is a light industrial with NO hydraulics other than the external hydraulics that power the loader. In other words, the seat sits on an empty sump. The loader fluid is in a separate tank mounted behind the seat. No 3ph or PTO on this one.
So, in this case I don't think it would matter much if he wanted to put 80W-90 gear oil in the trans and diffy since I assume the pto hole between the sumps is blocked off somehow. Plus if any did leak into that empty cavern, it wouldn't hurt anything.
soundguy
05-18-2013 12:41:08
 Re: Fluids Ford 4000 Industrial in reply to Jim.UT, 05-18-2013 10:15:14
i very much doubt the pto hole is blocked. I believe it will simply make it a common sump... and as you surmise.. with no hyds onboard. gear oil is fine.
