Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 901 Parts Online
Re: Ford 901 Select O Speed Mystery
Jchampiii
05-14-2013 09:37:30
The OD of the pipe is 1/2 inch. I like the sound of the compression adapters. We were just going to use some stainless steel hose clamps. We don't want to weld because we like the idea of giving it a little bit of flex.
John Smith8N
05-14-2013 21:02:38
 Re: Ford 901 Select O Speed Mystery in reply to Jchampiii, 05-14-2013 09:37:30
The back end of that pipe just has an o-ring where it slips into the control valve. The rigidity of the pipe is the only thing that holds it in there under full system pressure. If you go with a rubber hose patch, remember it has to be solid enough to hold the rear end of the tube in place. A little too much flex and it will just blow the fitting back out of the valve under pressure.
JChamp
05-15-2013 06:46:56
 Re: Ford 901 Select O Speed Mystery in reply to John Smith8N, 05-14-2013 21:02:38
(<-- father of the OP)
Yes, the break is so clean we figured that we would not trim the tube. that way any back pressure would be pipe-to-pipe.
I think we're going to go with the compression fittings with Hyd hose patch. I like the lateral flexibility that would introduce and keep a new ($150 O_O) pipe from breaking again.
soundguy
05-14-2013 13:01:08
i've personally used the 3/8 hyd compression fittings. i'm guessing 1/2 are available.
a buddy made me up some 8" hoses with orb fitting on one end and the comp fitting on the other.
worked good for a PS line replacement, unioning it with the existing hard line.
