TractorLinks.com
Order Ford 801 Parts Online
Re: 801 Ford Power Steering
Ultradog MN
05-13-2013 18:10:02
I'd be tempted to put a guage on the pump and verify what kind of pressure it is putting out.
Should be around 6-700 lbs pressure.
Otherwise you are just kinda shooting in the dark.
If the pump checks out then it's time to pull the tin off and go through the hydraulic block in the steering column.
They get crud and rust in them or the little springs can break and do not operate properly.
They are easy to go through and parts are available from CNH.
If you do go through the block post back and we can give you a few pointers to help.
The only parts on the original steering cylinders that are replaceable is the seal where the rod comes out. But even if they were leaking badly that is not likely your problem.
AFORD
05-14-2013 05:11:07
 Re: 801 Ford Power Steering in reply to Ultradog MN, 05-13-2013 18:10:02
Do you deadhead the pump with a pressure gauge to check or parallel the HP line with a tap? Thanks for the replies.
