Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 2000 Parts Online
Re: 2000 PTO disengages under load
Mike(NEOhio)
05-13-2013 17:02:37
In and out play could be that the shaft is moving in the bearing or the bearing is moving in the housing. I've had both at times. It happens when the implement's power shaft is a little too long and when lowered the shaft collapses until it bottoms out. Then it punches the shaft causing the oil seal ring to slip or the bearing breaks the snap ring that keeps it in the housing. If you're lucky, the ring braaks before the housing groove.
Copyright © 1997-2015 Yesterday's Tractor Co.
