Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 901 Parts Online
Re: Ford 901 Select O Speed Mystery
Larry NCKS
05-13-2013 16:54:33
Sorry, can't help on the tube. I can tell you, however, that if the transmission lost all hydraulic pressure your PTO will not work either. It depends on transmission pump and other components to make it run. You are correct that the 3 pt and other hydraulics pass through
Jchampiii
05-13-2013 16:57:36
 Re: Ford 901 Select O Speed Mystery in reply to Larry NCKS, 05-13-2013 16:54:33
You are correct. I forgot about the engaging and disabling the Pto. I'm used to the 8n where it's all mechanical. Haha I saw it was ran off the input shaft and for got about the clutch it has attached to it.
Copyright © 1997-2015 Yesterday's Tractor Co.
