TractorLinks.com
Show Parts for Model:
Re: Perplexing alternator problem
Hobo,NC
05-08-2013 18:48:39
Unless you think its cool to run a amp meter I would ditch it and install a voltmeter,,, as you can see the amp reading was of little value VOLTS were..
One posted just muddied the water you can not be all over the place the voltage range is not variable (like 13 to 14V)... All your testing needs to be done with a know good fully charged battery ( that includes the battery in your tester volt meter)...
You can test the grounds and every connection by doing a voltage drop test...
