TractorLinks.com
Show Parts for Model:
Re: Perplexing alternator problem
Greg1959
05-08-2013 17:35:07
Rod
Ground is good. Everything else was done as you stated except for the 194 bulb. AMP meter is 60 amp. I beg to differ on the 2000 rpm revs. That seems kind of high.
I appreciate your advice.
RodInNS
05-08-2013 18:12:39
 Re: Perplexing alternator problem in reply to Greg1959, 05-08-2013 17:35:07
It should charge at a lot less than 2000 rpm... but without knowing what you've got on it for a pulley... I say 2K to be certain. Some will charge at 800. Some less if they've been setup with a low cut in.
If all has been done and it still won't charge, replace it.
Just the same... I'm not a big believer in the idea that 2 have now burned out for no reason... Make sure there isn't something grounding out and making smoke somewhere else in the system. That WILL fry the reg... sometimes.
Rod
Greg1959
05-08-2013 18:17:58
 Re: Perplexing alternator problem in reply to RodInNS, 05-08-2013 18:12:39
Rod
I'll re-check wiring in the morning for a possible ground.
Thanks again
