Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Perplexing alternator problem
Greg1959
05-08-2013 14:13:48
I did that at the onset of problem. Voltage read 12.38 from battery without tractor running. After starting, checked voltage at battery post on alternator. Still read 12.38 volts.
JMOR
05-08-2013 14:23:01
 Re: Perplexing alternator problem in reply to Greg1959, 05-08-2013 14:13:48
Quoting Removed, click Modern View to see No climb = no alternator output. Alt not working.
You can do another test, but unless you are just curious or want to dig into the alt internals, it isn't worth much. It tells you whether the problem is the VR or some other area of the alternator. On the back side of alt is a "D" shaped hole. Inside that hole is a small metal tab. When a screwdriver is inserted & touches tab, it shorts that tab to the side of the "D" hole and this will provide full field current and if all else is well the alternator will output its maximum.
[URL=http://s192.photobucket.com/user/JMOR_photo/media/Charging/10SI_rear_labeled-1.jpg.html][/URL]
Greg1959
05-08-2013 14:42:43
 Re: Perplexing alternator problem in reply to JMOR, 05-08-2013 14:23:01
JMOR
That's interesting information.
Thanks
