TractorLinks.com
Show Parts for Model:
Re: Perplexing alternator problem
Greg1959
05-08-2013 12:41:35
: Run a wire from the + side of the battery to the diode the side that is hooked to the alternator. If it charges then you have a problem with you wire or diode."
Ran jumper...no charge.
"If it does not try the magnet test and see if you lay say a small nut on the center bushing area of the alternator if it sticks. If it does not stick it is not exciting so you may have a new bad alternator."
Nut- Does not stick.
Thanks
old
05-08-2013 14:59:10
 Re: Perplexing alternator problem in reply to Greg1959, 05-08-2013 12:41:35
Sounds like you got a bad alternator right out of the box. I learned years ago to have them test them before I go out the door. Had more then one alternator and starter be bad from the get go
Greg1959
05-08-2013 15:04:40
 Re: Perplexing alternator problem in reply to old, 05-08-2013 14:59:10
I believe it is a bad alternator. Thanks. Bad thing is...it's a 40-45 minute drive (one-way) to NAPA.
old
05-08-2013 15:30:53
 Re: Perplexing alternator problem in reply to Greg1959, 05-08-2013 15:04:40
Ya know how that is. That is one reason to bench test it before going out the door if they can do it that is
