TractorLinks.com
Order Ford NAA Parts Online
Re: Golden Jubilee value
jgayman
05-08-2013 12:17:26
Assuming the problem is indeed the pump, on the NAA/Jube the hydraulic pump is on the side of the engine and is driven from the flywheel. If it's the older Vane style it will be nearly impossible to replace/fix/rebuild. If it's the piston-style you can get rebuild kits. You can replace a Vane pump with the more common Piston pump but to do so you will need replacement hydraulic lines which are very hard to find.
Dean
05-08-2013 18:28:55
 Re: Golden Jubilee value in reply to jgayman, 05-08-2013 12:17:26
Actually, the pump is driven by the camshaft.
Dean
