4Having trouble starting my Ford 850. Starter disengages from flywheel after about a second of cranking - then "whirrs" to a stop. If I turn off the ignition and jump directly from battery terminal to starter post, then starter will crank for as long as I hold the connection.
Battery is at 12.44 volts - no load
11.0 volts keyed ignition start (after disengagement)
9.5 volts jump cranking.
This is a 12V electronic ignition conversion with original 6V starter.
