TractorLinks.com
Order Ford NAA Parts Online
Re: Golden Jubilee value
reb-in-pa
05-08-2013 11:52:13
If you can rebuild the pump and cure the problem, $50. If you buy a used pump and install it, and it solves the problem, $150-200. If you buy a newly rebuilt pump and install it, and it solves the problem, $350-400. If you have to take the top cover off and replace cam follower pin, o-rings, and seals, and you do your own work, another $50. If you pay a dealer to take the top cover off, etc., many hundreds.
Good luck.
Ray
jgayman
05-08-2013 12:17:26
 Re: Golden Jubilee value in reply to reb-in-pa, 05-08-2013 11:52:13
Assuming the problem is indeed the pump, on the NAA/Jube the hydraulic pump is on the side of the engine and is driven from the flywheel. If it's the older Vane style it will be nearly impossible to replace/fix/rebuild. If it's the piston-style you can get rebuild kits. You can replace a Vane pump with the more common Piston pump but to do so you will need replacement hydraulic lines which are very hard to find.
Dean
05-08-2013 18:28:55
 Re: Golden Jubilee value in reply to jgayman, 05-08-2013 12:17:26
Actually, the pump is driven by the camshaft.
Dean
