3400 drawbar mounts
Anonymous-0
Trying to piece together a 3400 that had the drawbar removed years ago. I located a drawbar but need the front mount and the rear mount that surrounds the PTO.Anyone know of a partsyard that is customer friendly?
Should be same set-up as 2000,3000,4000 3 cyl tractors. Be careful when it comes to installing the bolts, you could torque them right through the housing, and then you"d get a leak. Also, the pin that holds the front of the drawbar has a habit of falling out, so give it a check frequently.
From your description I wonder if you aren't talking about the old 2 piece drawbar mount like was found on the Hundred series Fords.
The drawbar mount for a 3 cylinder is a one piece affair and does not bolt up around the pto like the old ones do.
