TractorLinks.com
Order Ford 2600 Parts Online
Re: ford 2600 Lift arms
soundguy
05-07-2013 14:26:06
for kicks.. manipulate the draft control and see if there is any change int he position control height.
in any case.. I think you will find her ready for a new cam follower pin, perhaps some building up ont he cam.. and then a linkage adjustment using the shop manual. if it refers to using a nuday tool, look for the alternate instructions . all the nuday tool is is , esentially, a measuring device/ etc.
Larry Peterson
05-07-2013 16:32:56
 Re: ford 2600 Lift arms in reply to soundguy, 05-07-2013 14:26:06
Many Thanks,
I'll try the draft control, but it's actually the orchard variety and has only one lever. The draft control is a small lever on the right side below the seat. I'll let you know what results I get.
soundguy
05-07-2013 16:41:17
 Re: ford 2600 Lift arms in reply to Larry Peterson, 05-07-2013 16:32:56
no change to the directions. manipulate the draft control to see what it does to the position control.
Larry Peterson
05-09-2013 17:51:23
 Re: ford 2600 Lift arms in reply to soundguy, 05-07-2013 16:41:17
Hi,
No lift at all in draft mode. And When checking the oil level the FO-41 manual says arms up and all cylinders extended, but the owners manual says arms up and all cylinders retracted. Do you know which is correct?
Again Thanks
soundguy
05-09-2013 18:19:23
 Re: ford 2600 Lift arms in reply to Larry Peterson, 05-09-2013 17:51:23
it won't make a difference that you could see on the stick. the lift cyl volume is minutia compaired to sump volume...
if you have some large external hyds using SA cyls.. then it would make a difference..
