Ford 960 Wide Front Tie Rod Ends
FarmerZeb
Does anyone have a parts source or alternate solution for the tie rod ends on a 960 wide front. Parts Key#30 in the diagram. They are NLA from New Holland and no aftermarkets seem to be available.
thanks,
Paul
i'd just find a pin that fits the socket and go with a cut n paste. had to do that on a 541 offset. real late 960 you got, or had a 2 piece WFE and pedistal swapped in?
I researched the archives and found a few threads suggesting a tie rod end off a 78 chevy 3/4 ton truck matches the taper but a cut and weld is required.
my 960 is a late sn with a factory front end
-paul
Hi, Do you have OEM part numbers?? I have 3 new old stock joints that I would like to sell. Thanks Jim --No-Advertising-in-Forums
309503
Kit, Spindle Connecting Rod Spindle Arm End Includes: End Assy., Dust Cover, Lube Fitting, Hex Nut, & Cotter Pin., Start Year: 01-JAN-57
