TractorLinks.com
Show Parts for Model:
Re: valve noise?
Hobo,NC
05-02-2013 05:34:31
You still need to locate the tick,,, it could be a exhaust leak.
If you have not adjusted the valves I would adjust them once adjusted are even before you can determine were the tick is if its a adjustment issue.
If adjusted proper it should not tick run it with the valve cover off... None of my tractors have valve noise because I was taught how to get them way not to live with it... The only way I would live with it is if it were not possible to run it with the valve cover off are if adjusted with in a few tho of spec on the tight side and it still ticked... if that's the case adjust to spec and live with it but until this is determined that's no reason to live with it from hear say....
