Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 3000 Parts Online
Re: ford 3000 3 point hitch trouble
RodInNS
05-01-2013 19:15:17
Probably in the flow control valve... IIRC, there is a spool in there that allows excess flow to be dumped to sump. If the valve sticks and doesn't shift for a fast lift... most flow is dumped to sump and low pressure. Valve will be by your right heel as you sit in the seat.
Rod
unhappy ford 300
05-01-2013 19:52:40
 Re: ford 3000 3 point hitch trouble in reply to RodInNS, 05-01-2013 19:15:17
is that the valve located in the sump draian valve
RodInNS
05-01-2013 20:30:25
 Re: ford 3000 3 point hitch trouble in reply to unhappy ford 300, 05-01-2013 19:52:40
It's located in the hydraulic manifold... above the releif valve and just below the lift cover. It's bolted into the side of the rear axle center housing. Should have a black finger knob on it.
Rod
Copyright © 1997-2015 Yesterday's Tractor Co.
