TractorLinks.com
Show Parts for Model:
hydraulic lift control valve adjustment tool
Jay Pea
05-01-2013 11:18:19
Showcrop suggested that I check this forum for specs related to a Ford special tool NCA-502 used to adjust the control valve on the lift cover for a 1955 Ford 641. If someone knows the specs on the gauge I"ll make a few.
DollarBill
05-02-2013 03:49:15
 Re: hydraulic lift control valve adjustment tool in reply to Jay Pea, 05-01-2013 11:18:19
Can I be your friend :D
JMOR
05-01-2013 12:03:35
Quoting Removed, click Modern View to seeReading of FO-20, indicates 0.395-0.397 inch for draft & 0.448-0.450 inch for Position ctrl. If I recall correctly, the exact surface measured to or reference is somewhat of a question, because of the retainer plate.
Dean
05-01-2013 11:56:25
I believe that the specs were posted here one time in the past but do not have the information at hand.
I would be interested in one if you reproduce them.
Another tool that would be handy and, I believe, necessary for use with the NCA-502 gage is the lift arm positioning fixture (do not have the Nuday number here).
Dean
welding man
05-04-2013 14:53:16
 Re: hydraulic lift control valve adjustment tool in reply to Dean, 05-01-2013 11:56:25
JMOR and others here is a sketch of the NCA-503 1955 and up. The N-503 is for Jub and NAA. I am not a draftsman,I hope you understand the drawing.
JMOR
05-04-2013 14:57:49
 Re: hydraulic lift control valve adjustment tool in reply to welding man, 05-04-2013 14:53:16
Looks good to me! I'm sure all will appreciate it. Any comments on the HC-101 sketch that I posted?
welding man
05-04-2013 17:26:23
 Re: hydraulic lift control valve adjustment tool in reply to JMOR, 05-04-2013 14:57:49
I have never used the HG-101. Most of my work on the N series tractors have been engine, clutch, and transmission related.I have not worked on too many with hydraulic problems.Most of my work is on the Blue Fords 1965 and up 3000 thru TW-5. I have these tools because I bought everything the old Ford dealer had, including the valve grinding equipment and rod bushing hone.
JMOR
05-04-2013 19:44:00
 Re: hydraulic lift control valve adjustment tool in reply to welding man, 05-04-2013 17:26:23
OK. Thanks for everything in all the info on rare tools. If you wouldn't mind correspondence by e-mail or phone, send me an e-mail. My e-mail is open on Modern view & on this message in Classic view.
welding man
05-01-2013 20:38:28
I have them all if anyone would like pictures and measurements.I think I have all the Ford tractor tools from the N's through the 10 series,including 2 clutch fixtures and the 8N govenor fixture and some SOS tools. Many I have never used.I got them all when New Holland yanked the local dealership and the owner happened to be my friend.
Jay Pea
05-02-2013 04:09:07
 Re: hydraulic lift control valve adjustment tool in reply to welding man, 05-01-2013 20:38:28
Finding someone with these tools is great as they are becoming so rare. Pictures and measurements of the NCA-502 Gauge and the NCA-503-B Lift Arm Holding Fixture would be extremely helpful. My shop manual shows both of these tools so I know what they look like. I really need the specs so I can make them.
welding man
05-02-2013 18:31:34
 Re: hydraulic lift control valve adjustment tool in reply to Jay Pea, 05-02-2013 04:09:07
Finally got around to hunting the guage and making a quick sketch.I also have a SW-508-A for the later tractors.I have all the tools that Dean mentioned but do not relly know how to get any accurate measurements on them. Any questions, just ask.
Jay Pea
05-03-2013 12:17:40
 Re: hydraulic lift control valve adjustment tool in reply to welding man, 05-02-2013 18:31:34
Thanks welding man! That's exactly what I needed. The 502 tool will be very easy to reproduce. The 503 and the 503-B is a different animal. Thanks again!
JMOR
05-03-2013 08:45:09
The important dimension for the 503 tool will be the vertical distance from the top cover gasket surface up to the center line of the pin going thru fixture & lift arm.
welding man
05-03-2013 10:13:35
 Re: hydraulic lift control valve adjustment tool in reply to JMOR, 05-03-2013 08:45:09
Actually there are 3 fixtures- NCA-503 -N-503 and a HG 101. Take your pick.
JMOR
05-03-2013 11:17:32
 Re: hydraulic lift control valve adjustment tool in reply to welding man, 05-03-2013 10:13:35
Quoting Removed, click Modern View to seeI was speaking of dimension regarding the two 503 tools. I see that you have the HC-100 for setting the 8N control rod position as well.....a rare critter! I can't read the word after 'finished' and before 'indicates'???
welding man
05-03-2013 19:32:07
 Re: hydraulic lift control valve adjustment tool in reply to JMOR, 05-03-2013 11:17:32
JMOR, I will try to figure out some way to get you some accurate measurements tomorrow. The writing on the HG 101 says (finished edge indicates center line of ball with an arrow pointing to a hole. The very end has 2 notches, one for draft and one for position.
JMOR
05-03-2013 20:10:18
 Re: hydraulic lift control valve adjustment tool in reply to welding man, 05-03-2013 19:32:07
That HG-101 is really intriguing! As for the other two, if you can clamp the bolted part down to a real flat surface & then measure from that surface up to center line of the hole for lift arm pin, I believe that defines the dimension it was intended to set. Some real neat items to own, for sure!
The HG-101 is probably like the attached sketch (can't see the full part in your picture).
[URL=http://s192.photobucket.com/user/JMOR_photo/media/Hydraulics_PTO/adjust_tool_HC-101.jpg.html][/URL]
welding man
05-04-2013 06:13:11
 Re: hydraulic lift control valve adjustment tool in reply to JMOR, 05-03-2013 20:10:18
JMOR the 503 fixtures are exactly opposite of what you are thinking,if you clamp them down flat,the hole is down,not up,plus the distance from the top bolt hole to the center of the pin hole is critical, and the offset to the right is different on both.
