TractorLinks.com
Order Ford NAA Parts Online
Re: NAA weak hydraulic pump?
Kurt-NEPA
04-30-2013 11:39:40
Tuna, I think you are looking at a pump rebuild. Loosing the prime overnight is a classic sign of a failed pump shaft seal. Over the years, the seal wears a groove in the wobble shaft that requires replacing both. In order to do that you will have to replace both bearing.
I also think you will find that you have check valve problems on several cylinders. Replacing the balls and springs is a fairly easy fix.
If you are up to a full pump rebuild, post back and we can help. Its a little more involved than normal wrenching.
Tuna IL
04-30-2013 16:59:46
 Re: NAA weak hydraulic pump? in reply to Kurt-NEPA, 04-30-2013 11:39:40
Thanks, I will go for the full pump rebuild, It will be a month or two as I drive OTR. Until then I keep reading on here.
thanks
charlie
