TractorLinks.com
Order Ford 861 Parts Online
Re: 861 running hot
dwb-ne
04-30-2013 09:13:08
I set points to .025 I blew out radiator with air hose I can see thermostat open on the temp gauge. How do i check if water pump is circulating water properly? I will check carb and richen it up and see what happens.
Thanks For Everyone's Input!
old
04-30-2013 09:29:59
 Re: 861 running hot in reply to dwb-ne, 04-30-2013 09:13:08
Pull the radiator cap off then start it and when the thermostat opens you should see coolant moving. Another thing to check is make sure the fan belt is nice and tight. A slipping belt will slow down the fan and that can cause it to run hot also
