TractorLinks.com
Order Ford NAA Parts Online
Re: NAA weak hydraulic pump?
Tuna IL
04-30-2013 08:32:52
So I need to pull the side inspection cover and check for leaks form the piston?
old
04-30-2013 08:56:18
 Re: NAA weak hydraulic pump? in reply to Tuna IL, 04-30-2013 08:32:52
Yep first thing to do is pull the dip stick inspection plate and have a look see. As for loosing prime that maybe worse problems like a pin hole in a line that runs threw the transmission
soundguy
04-30-2013 09:03:32
 Re: NAA weak hydraulic pump? in reply to old, 04-30-2013 08:56:18
actually not so bad on the naa.. the naa uses external lines that run under the tractor.. not them bajeebers that run thru the tranny.
