Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Another Ford
TONY JACOBS
04-30-2013 07:14:20
Hello Paul , As far as locating a narrow bucket for the Hoe that will be tough find after all these years , the wide buckets are much more common and less worn . Usually I take a wide bucket and cut the sides off narrow the center section to the desired width and weld the sides back on and replace the cutting edge and side cutters at the same time then reinstall the teeth . It is not a job for the back yard welder either because you will be working with very HARD T-1 Steel in the cutting edges if you want it to last . I would assume you know a good local welder then you would be all set . As far as the power steering goes seal kits for the pump are available as are steering box parts from New Holland the front tie rod ends are a little tougher to find and the rears I usually cut them off and use the replaceable ones from Manual steering tie rods after welding a piece of the threaded end from the manual steering tie rod on them then just thread the ends in and tighten the clamp . Thanks Tony
Copyright © 1997-2015 Yesterday's Tractor Co.
