TractorLinks.com
Show Parts for Model:
Re: valve noise?
old
04-29-2013 19:27:15
I was taught that is was better to here a little tappet noise then to not here it. Reason is if you hear it then you know the valves are not being held open but if you do not then you can not be sure. Of course my first car did not have hyd lifters so learned they need to tap tap a bit or you ended up with burnt valves
petetherookie
04-30-2013 05:03:04
 Re: valve noise? in reply to old, 04-29-2013 19:27:15
I still have the burnt exhaust valve from my '74 Toyota sitting on my desk. Teenage over zealous valve adjustment being the culprit. Celica engine sounded quiet and ran great till it ate that valve!
Pete
old
04-30-2013 08:05:56
 Re: valve noise? in reply to petetherookie, 04-30-2013 05:03:04
Yep as I said better to hear them then to have them burn
36 coupe
05-02-2013 03:34:42
 Re: valve noise? in reply to old, 04-30-2013 08:05:56
I have always set valve gaps wider.Before hydraulic lifters I checked new Fords and found a few were too tight on one or two valves.Chevy 6 cyl were bad for burning valves because they were set tight.
Texasmark1
05-02-2013 15:27:34
 Re: valve noise? in reply to 36 coupe, 05-02-2013 03:34:42
In 1964 I bought a new Rambler American, the last year for the old 3 main bearing 6 cyl design. I forget the time span, not much, but to maintain the warranty I had to bring it back to the dealer to have the head torqued and valves reset. Never had before nor sense.
I don't know if their upgraded 6 which had 7 mains had that reaquirement.
Mark
36 coupe
05-04-2013 16:55:21
 Re: valve noise? in reply to Texasmark1, 05-02-2013 15:27:34
I had a 61 rambler that had to have the head milled to keep a head gasket in it.I bought a 64 Rambler V8 that was a nice car.Both were well used when I bought them.
David G
04-30-2013 04:57:46
Old,
I totally agree.
