Dew3600
New User
I need HELP!
I have a 3600 gaser that the 3pt worked fine last winter when it was parked. I went out today to hook up the mower and the 3pt won't move up or down. Any help would be greatly appreciated!
Try the easy things first.
Could a remote hyd handle be pulled back (or pushed forward) to the detent? If a remote is engaged you will have no 3 pt lift.
Also, have you tried to bleed it? Loosen (but don't remove) the nut on the pressure side of the pump. Run the engine at idle and let it puke oil till it stops spitting and or bubbling. Then retighten. If it is easier you can also do it from underneath. (second photo)
That was what it was the lift control lever was in the full forward position thank you very much Ultradog for your advice.
There's no need to bleed the gear pump on a 3600.... although opening a line where you pointed would confirm quickly wether or not it's moving oil.
Most likely cause of inaction is a stuck unloader provided all other controls are where they should be.
Rod
