Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 860 Parts Online
Re: 860 Sputtering Under PTO Load
old
04-29-2013 12:24:31
Carefully remove the gas cap and make sure the gas is not boiling or the tank vent is clogged. Either will cause that. Also is the fuel line factory or other then??? Fuel lines can and does get hot and that in turn causes the gas to biol in the line and that will cause that problem also
ThadS
04-29-2013 12:36:03
 Re: 860 Sputtering Under PTO Load in reply to old, 04-29-2013 12:24:31
I have removed the gas cap to add more fuel and the gas is not boiling.
It is the original gas line as far as I can tell from the parts manual picture.
Thank you,
Thad
jeff pk
04-29-2013 13:26:31
 Re: 860 Sputtering Under PTO Load in reply to ThadS, 04-29-2013 12:36:03
If it happens when the engine is at its hottest, it's possible there's a crack in your exhaust manifold or a leaking gasket that only opens when very hot---this will cause surging
