Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 860 Parts Online
Re: 860 Sputtering Under PTO Load
showcrop
04-29-2013 12:06:55
It sounds like you must be getting fuel, but you should still check for good flow. With the tractor cold take the drain plug out of the bottom of the carb and ascertain that the fuel will run strongly for a good thirty seconds. You also need to verify spark immediately after it quits by removing a plug and grounding against the block then crank the motor. you need a spark that will jump 1/4 inch.
