Fuddy Duddy
The 4000 I recently bought will only raise the 3 point 24 inches
measuring from the ground to the center of the little eye/ball
thingy. My 8N goes up to 34 inches. I believe the position control
lever should be able to lift up. But there is an elbow from the
remote hydraulics there with a plug in it. I've tried to push it
down. Don't seem to go that way. Remove the ellbow and just
put in a plug? Then the PO left something on the lift arm I'm not
sure what it was used for. Maybe some implement had a
hydraulic cylinder that would hook there. When the arm is up all
the way to the 24 inches there is about one inch of clearance
from it and the axle housing. Did maybe the PO fix the lift so it
won't raise up all the way? Is the max height adjustable some
way?
way?
