Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: ford specs
Sean in PA
04-28-2013 19:11:26
The rear axle housing fluid is used as a lubricant for the differential, plus it is the hydraulic fluid for the 3 point lift, plus it is the oil that cools the wet brakes, so you need to use a UTF that says on the label that it meets or exceeds the Ford/New Holland M2C134D specification. You can use the same UTF in the transmission, or you can use gear oil (80W, 90W or 85W/145, depending on what temperatures you'll be running it in).
