TractorLinks.com
Show Parts for Model:
Re: brake drum
Hobo,NC
04-28-2013 18:43:35
[quote="Harmlar"](quoted from post at 04:31:30 04/29/13) from previous post i know the brake drum has to come off to replace the axle housing on 631.
the drum on my 631 should have screws it does not the hub must be removed to get the drum off can you tell by the pic what tractor the drum is for
If you are replacing the trumpet (axle housing) the brake drum does not have to come off... If it does I am open as to why... I believe your hang up is the brake actuator shaft that goes in the backing plate it stays in the backing plate,,,, the other end slips into the rear housing... You disconnect what ever actuates it (pedal linkage) and it comes with the assembly (axle, backing plate and bearing support)...
Harmlar
04-29-2013 06:59:18
 Re: brake drum in reply to Hobo,NC, 04-28-2013 18:43:35
The brake actuator has been disconnected that was one of the first things done it is free
