TractorLinks.com
Show Parts for Model:
Re: brake drum
Kurt-NEPA
04-28-2013 18:15:00
Sure looks like the drum on my 660.
Remove the axle extension to see the screws that are underneath them (that is if they are still there - they often get left off).
Once the extension is off, the screws are out (they can be a bear), and the brakes are backed off, you can get the drum off with several more than gentle taps with a BFH. Is that what you are trying to do?
Harmlar
04-28-2013 20:00:00
 Re: brake drum in reply to Kurt-NEPA, 04-28-2013 18:15:00
i just want to replace the trumphet
soundguy
04-29-2013 06:50:04
 Re: brake drum in reply to Harmlar, 04-28-2013 20:00:00
it will come out as a unit but it's going to be much lighter with that AXLE SPACER and drum off. your call.
hobo gave you good advise as to what may be hanigng it up.
ps.. that thing on the drum is not a hub.. it's a spacer!
Harmlar
04-29-2013 07:01:21
 Re: brake drum in reply to soundguy, 04-29-2013 06:50:04
Ok but it is still hung up the brake acuator is free
soundguy
04-29-2013 07:07:42
 Re: brake drum in reply to Harmlar, 04-29-2013 07:01:21
have you tried tapping on it?
this is why many of us told you to remove the drum. less weight to deal with. less mass to move when fidgeting it out.
again. your call.
Harmlar
04-29-2013 09:09:11
 Re: brake drum in reply to soundguy, 04-29-2013 07:07:42
Well i went in the house had two more cups of coffee and went back out to pull and hammer now got it out at my age just a little short of the ole muscle now when i get ready to put it back in will it line up ok
soundguy
04-29-2013 11:23:58
 Re: brake drum in reply to Harmlar, 04-29-2013 09:09:11
that's why most of us advised pulling the brake drum and that axle spacer.
it's alot of metal to move.
I wear a back brace now and can't pull entire assemblies like I could a few years ago.
same with hammering.. if you have less mass to move. it moves easier..
just curious.. what's wrong with the axle trumpet anyway..
Harmlar
04-29-2013 08:09:59
just got done pulling and tapping still won't budge
sounds like it is hug up on the other end of the axle
Harmlar
04-29-2013 07:35:43
Good advice to remove the drum it has to be removed from the trumphet anyway yes i have done a little more then tapping on it with a rubber mallet the brake has been released with adjuster and i can turn the drum like i mentioned it about 13/4 inch out from the trumphet still hung up
soundguy
04-29-2013 11:21:43
 Re: brake drum in reply to Harmlar, 04-29-2013 07:35:43
rubber mallet?
put the sissy tools down and go get some real man tools... :)
Harmlar
04-29-2013 12:16:36
 Re: brake drum in reply to soundguy, 04-29-2013 11:21:43
i have bigger and heavy tools but I'm only 1/2 the man i use to be. all kiddin aside didn't want to pound on the brake drum to hard with big hammer for fear might damage it
soundguy
04-30-2013 07:02:25
 Re: brake drum in reply to Harmlar, 04-29-2013 12:16:36
i hear ya on the half the man thing.
lately i'm wearing a back brace full time and ankle and knee braces.
the drum will hold up good to tapping with a maul. I've found the rubber mallet bounces back and doesn't have enough mass some times.
for good saftey.. get a deadblow hammer.. no bounce.. and it still can have good mass.
