TractorLinks.com
Show Parts for Model:
Re: axel housing
Hobo,NC
04-28-2013 15:32:08
If you have all 9 nuts removed at the bearing support (back side) AND the linkage at the brake shaft somewhere near the rear housing the brake control shaft will come with the brake backing plate intact... You will be ablel to remove it as a assyembly no need to remove the drum are anything else unless you plan to service/replace brakes and seals,,, you were told right and the way I would go after it if all I was doing was replacing the trumpet only...
souNdguy
04-29-2013 05:29:25
 Re: axel housing in reply to Hobo,NC, 04-28-2013 15:32:08
going that far why not inspect the brakes though?
and take that heavy drum off to make it all eaiser to manhandle?
