If it does not have a loader frame limiting access to the grille shell, I'd remove the muffler, hood, grille shell & radiator, then swap out the water pump. Hoses and thermostat are subject to getting tossed, and it's a great time to take a pressure washer to the radiator.
I don't know about using a pressure washer on the radiator, it probably would bend the fins over.
I use a water hose to clean mine.
Done it dozens of times, no problem. just keep the nozzle back a little ways, and come at it straight on, not at an angle. Like many things, care & common sense help. If you set out to ruin a radiator with a pressure washer, it certainly can be done.
