Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 861 Parts Online
Re: 861 hydraulic system
Kurt-NEPA
04-28-2013 14:25:42
I think I would try to bleed it again. Chatter is a classic sign of air in pump. If that work - great.
If that fails, try the clear plastic hose test. Remove the pipe plug on the pump. Inset a street elbow, then a nipple, then a ball valve, then a hose barb to transition to a clear plastic hose. Run the hose back to the hydraulic sump fill hole under seat. Open the valve and start the tractor. Do you see bubbles in the hose? If yes run the tractor until they stop, then close the valve. Check the lift. If all is well - great. If the bubbles never stop, then you probably need a pump rebuild.
Post back we can help.
