Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Ford tractor won't start
Case dozer
04-27-2013 17:27:57
Sorry wrote it Wong I replaced the battery a week ago and today can't get it to start unless it's pulled off tested battery with load tester it's good
Greg1959
04-27-2013 17:39:33
 Re: Ford tractor won't start in reply to Case dozer, 04-27-2013 17:27:57
Are you meaning that you had to 'pull' the tractor to get it started?
Case dozer
04-27-2013 17:45:26
 Re: Ford tractor won't start in reply to Greg1959, 04-27-2013 17:39:33
I can start it with screwdriver on starter but can't start with switch
soundguy
04-27-2013 18:53:19
 Re: Ford tractor won't start in reply to Case dozer, 04-27-2013 17:45:26
if there is plenty of bat power to start it by arcng solenoid.. but won't key start. check NS switch.. run the range selector backa nd forth while holding the key in start and see if she tries to go.
Case dozer
04-27-2013 19:26:51
 Re: Ford tractor won't start in reply to soundguy, 04-27-2013 18:53:19
Will that make where the dash won't light up at all
soundguy
04-29-2013 05:34:41
 Re: Ford tractor won't start in reply to Case dozer, 04-27-2013 19:26:51
have you checked the fuse behind the dash?
Case dozer
04-30-2013 19:49:11
 Re: Ford tractor won't start in reply to soundguy, 04-29-2013 05:34:41
Quoting Removed, click Modern View to seeyes it's good but the dash will light up first time you go to start After that nothing comes on at all!
Case dozer
04-30-2013 19:48:55
Copyright © 1997-2015 Yesterday's Tractor Co.
