TractorLinks.com
Show Parts for Model:
Re: axel housing
Harmlar
04-26-2013 15:55:07
doesn't the drum and axle come off together
soundguy
04-26-2013 17:01:47
 Re: axel housing in reply to Harmlar, 04-26-2013 15:55:07
have you not botheres to read ANY of the replies in this thread???
back the brakes off and get that drum off first.
Harmlar
04-26-2013 17:19:06
 Re: axel housing in reply to soundguy, 04-26-2013 17:01:47
I need to tell you what i have done now.
I have the nuts removed that fasten the drum to the axle housing and it is pulled away from the housing about 1& 3/4 inch
soundguy
04-26-2013 17:43:18
 Re: axel housing in reply to Harmlar, 04-26-2013 17:19:06
have you backed the brakes off.
have you removed the screws holding the drum on
have you removed the drum.
go back till you get that step done.
Harmlar
04-26-2013 17:13:10
Yes i have read the previous post, I was told that by local mech that drum & axel would come together where i realy got confused. will work on the drum removal first and then the axel
soundguy
04-26-2013 17:44:17
 Re: axel housing in reply to Harmlar, 04-26-2013 17:13:10
i'd stop listening to the local mechanic that thinks you are working on a 9n or 2n...
soundguy
04-26-2013 18:06:52
 Re: axel housing in reply to Harmlar, 04-26-2013 18:00:46
good luck with the repair.
This post was edited by souNdguy at 18:07:56 04/26/13.
Harmlar
04-27-2013 06:21:47
 Re: axel housing in reply to soundguy, 04-26-2013 18:06:52
If only I knew more about mechanics anyway thanks next time I'll know where to go first
Bill Radford
04-26-2013 18:25:24
Listen to SG... the drum MUST come off before you do anything else..you are hanging up on the shoes that are catching on the ridge that has been worn in the drum. Unless you totally back the adjusters off, you may crack the drum by beating on it.
HCooke
04-27-2013 06:34:16
 Re: axel housing in reply to Bill Radford, 04-26-2013 18:25:24
Yep!!!
