Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: axel housing
Sean in PA
04-26-2013 14:31:19
Which are you trying to remove at this point, the brake drum or the axle shaft? The brake drum should come off separately first. If the drum is moving a little and then won't move any more, then the shoes are probably catching on a lip on the back edge of the drum. Have you adjusted the star wheel adjuster all of the way to the loose end of it's adjustment? If so, and it's still catching, you may need a bigger hammer.
Harmlar
04-26-2013 15:11:23
 Re: axel housing in reply to Sean in PA, 04-26-2013 14:31:19
I want to replace the axle housing so I need to pull the axle out. I now have the brake drum about 1 3/4 inch out of the housing and it won't go any more.
