Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 960 Parts Online
Re: 1960 Ford 641 won't start
04-25-2013 19:10:24
Do you have battery voltage to the coil?
If so, what's on the distributor side of the coil?
It should be zero when the points are closed,
battery voltage when they're open.
If it is always zero, the points aren't opening,
something in the distributor is grounded or
less likely, a bad coil.
If it is always battery voltage, the points aren't closing/making contact.
Turning over slow is often dirty battery cable connections.
Either on the battery or where they connect to the tractor.
Let us know what you find.
