TractorLinks.com
Show Parts for Model:
Re: 12volt conversation
soundguy
04-20-2013 12:53:25
you might throw us a bone and tell us what machine this is.
and saying 'old school solenoid' means nothing.
and yuo will need to describe the wireing that YOU did, and what was present before we can guess how bad you miswired it to make a lamp come on pressing 'some' start button.
you give.. then we give. :)
post back
Tony9031
04-20-2013 14:17:01
 Re: 12volt conversation in reply to soundguy, 04-20-2013 12:53:25
Sorry bout leaving out info, aggravation had set in. Lol
It's a 1958 ford 861, it had a 6 volt wiring harness, 6 volt everything. With the new 12 volt harness, one wire alternator that feeds from alternator wired with together with another comeing off of solnoid thats with the battery cable to the indicator light.those are red. Have yellow wire from solnoid to starter switch. Orange wire from solnoid to terminal block, with white wire going to 12volt coil, plus one to toggle switch. Toggle replaced key switch. Other side of terminal block, is wire to toggle switch, and one to indicator light. Plus cable from solnoid to starter.
soundguy
04-20-2013 14:33:27
 Re: 12volt conversation in reply to Tony9031, 04-20-2013 14:17:01
pry the plug out of the #1/#2 connection point if this is a gm 10 si alt and hookup one wire from the the red indicator lamp to #1.. for kicks.. jump #2 down to charge stud. hook t he other red indiscator lamp wire to ign side of ignition switch
the PROPER 4 post solenoid will need to be wired 1 big stud to starter.. one to bat hot.
1 lil stud to switched side of ignition, and one lil stud to thumb push button safety interlocked switch.
ign on should make red lamp come on.. after start and reaching 400 rpms, MAYBEE, red lamp may go off.. or the reg might need more rpm.. maybee 1200.. etc..
post back
Tony9031
04-20-2013 15:50:43
 Re: 12volt conversation in reply to soundguy, 04-20-2013 14:33:27
The solnoid your talking is right, It's hooked up that way , and the indicator light comes on and off with the toggle. But power is not reaching starter. I don't know the brand of alt but it does have the plug and connections your say, so should I still try to try the atl that way?
soundguy
04-20-2013 16:54:49
 Re: 12volt conversation in reply to Tony9031, 04-20-2013 15:50:43
if i didn't want you to try it.. why did i type it in?
if starter won't run.. RE CHECK your wires!!!
if you are getting power on one small termianl and grounding the other small termaoinal and it DOES NOT engage the solenoid.. it's the wrong solenoid.. or it's BAD...
KV bruce
04-20-2013 20:28:41
 Re: 12volt conversation in reply to soundguy, 04-20-2013 16:54:49
Chill out!
soundguy
04-22-2013 06:36:47
 Re: 12volt conversation in reply to KV bruce, 04-20-2013 20:28:41
i didn't see any expert knowledge from you on the situation.
your diagnosis thus far would be? what? silence as usual?
thought so...
soundguy
04-22-2013 06:35:16
you don't like my response? don't read it.
